Restoration & Repair Tips Board
adding 12volt altenator system to magneto ignitio
joe Smits
08-05-2004 18:03:03
Help! Tractor runs one hour and quits. Will not restart for a couple of hours since I added the 12 volt system. When i disconnect the battery the tractor runs 4 hrs+ Any ideas where to start?
Thanks Joe
Bob M
08-09-2004 07:07:16
 Re: adding 12volt altenator system to magneto ign in reply to joe Smits, 08-05-2004 18:03:03
Joe � That�s a puzzler� A true magneto operates completely independent of the rest of the electrical system - it doesn�t know (nor care) whether the starting/charging system is 6 volt, 12 volt or non-existent. Consequently your observed longer run time with the battery disconnected can only be by coincidence.
Suggest you try this: Reconnect the battery and run the tractor again. If/when it quits immediately pull a plug wire, hold the end about � inch from the block then crank the engine. If the mag is good you�ll see a fat, blue spark and know your problem is somewhere else. However if you get a weak yellow spark or no spark at all, the mag needs attention.
If I were to guess the problem is a failing coil or condenser in the mag � works OK when cool but not when the mag gets hot. Good luck and post back what you find!
PS � Thanks CNKS and txblu for your kind words! As you guys suggest this site is about helping each other...
CNKS
08-05-2004 18:19:21
A person named Bob M on the Farmall board provided these.
txblu
08-06-2004 06:08:28
 Re: adding 12volt altenator system to magneto ign in reply to CNKS, 08-05-2004 18:19:21
You're an example of what makes this site what it is.....Helping out a friend and giving credit where it's due. Bob has helped lots of folks with his diagrams.
Proud to post with you.
Mark
CNKS
08-06-2004 17:44:27
 Re: adding 12volt altenator system to magneto ign in reply to txblu, 08-06-2004 06:08:28
Thanks, Bob M has much more knowledge than me, so I believe in giving credit where credit is due.
Ol Chief
08-08-2004 19:26:57
 Re: adding 12volt altenator system to magneto ign in reply to CNKS, 08-06-2004 17:44:27
I got lost somewhere.There was no statement that the magneto is being removed so what is the 12 volt conversion doing to ignition that will stop the engine? I do not see any mention that a distrbuter is being added to the mix.As I read it the heading says magneto ignition and adding an alternator.Dont mean to be nit picking,just dont understand.
txblu
08-09-2004 09:26:38
 Re: adding 12volt altenator system to magneto ign in reply to Ol Chief , 08-08-2004 19:26:57
I think he just meant that he was changing the charging system, not the whole ignition. Course iffin he had a hand crank and no lights, he wouldn't have had to bother, would he?
Mark
