Restoration & Repair Tips Board
Problem with MF 1080
T213R
08-03-2004 19:56:23
I have a 1971 MF 1080 which I am repairing (can't say if this will be a restoration yet). Among it's problems is this: Both the Brake pedals and the clutch pedal are mounted on a common shaft. The left and right brake pedals are rusted together and both are rusted securely to the shaft. Depress the brakes and they work, but not independantly. Additionally, on the other side of the "dash", the clutch pedal is also rusted, securely, to the same common shaft, Once again, the clutch appears to work, but you get clutch AND brakes, together, by pressing either brake OR clutch pedal! ANy ideas about how to get these pedals freed up and working properly? I'm already soaking both the brake pedal pivot and the clutch pedal pivots, where the rust is , with JB80!
