Restoration & Repair Tips Board
bolens g14 and murphys law
Larry
08-02-2004 23:33:52
i have an old bolens g14 and replaced the engine after getting it back together and useing it once it seems the drive belts need replaceing.. is there a short cut for this or do i need to take the motor back off to get to it ?
Bob Whitmoyer
08-09-2004 18:11:06
 Re: bolens g14 and murphys law in reply to Larry, 08-02-2004 23:33:52
Hi
NOt a big problem.
Underside of tractor (follow belts) remove two
bolts from each side of the frame piece holding the front clutch bearing. Also remove the large nut on the front of the clutch/drive shaft end,.
This is where the lower pullies are located.
Remove plate and bearing. Remove belts, replace
in reverse order. Beats removing the engine
Have a great summer & Fall
Bob WHitmoyer
