Restoration & Repair Tips Board
Marvel Schebler TXS-157 Carb
Jeff H
07-26-2004 20:30:27
My 1946 Farmal B has a TSX-157 (gas only) carb. I am just starting the restoration and the guy who had it took the carb off because the gas was "running right through it." I would love to talk to somebody who is familiar with this carb.
Jeff
CNKS
07-27-2004 17:32:52
 Re: Marvel Schebler TXS-157 Carb in reply to Jeff H, 07-26-2004 20:30:27
Common problem, also make sure the float is not hanging up on the side of the bowl.
Ron
07-27-2004 08:54:58
"gas was running right through it" sounds like there is some dirt trapped between the float needle and seat, or they are damaged, or the float itself is damaged and/or the float level is set incorrectly.
Brad_fromTN
07-27-2004 12:38:16
 Re: Re: Marvel Schebler TXS-157 Carb in reply to Ron, 07-27-2004 08:54:58
Get a rebuild kit and go at it. These carb's are so simple ... very easy to work on.
