Restoration & Repair Tips Board
Rusted/Stuck Loader Controls
David Coe (MD)
07-24-2004 19:01:22
I'm trying to get a Ford 841 running (got the engine going OK), but can't get the loader to raise because the hydraulic control levers are stuck; probably just rusted -- the tractor has sat in the rain for 4 years or more without being started.
It does seem to have hydraulic fluid flowing through the controls.
Should I try penetrating oil, or something else, or try to disassemble the controls?
Thanks for your suggestions.
If you want to take a peek at them, look at the "loader_controls" pictures at this url...
Hydromaniac
07-26-2004 23:51:38
 Re: Rusted/Stuck Loader Controls in reply to David Coe (MD), 07-24-2004 19:01:22
If the spools are rusted and the levers are incapable of moving them, you've got a very contaminated hydraulic system that needs to be flushed out clean be fore you try to operate it . Otherwise you'll have rust particles and slime floating around blocking all the small orifices in the contol valves and playing havoc with your pump. Rust means water and that is very bad to have in your hydraulics. Try disconnecting a cylinder hose when the system is NOT PRESSURIZED and see what the fluid looks like. THAT will tell you a bunch. Good luck. I have an 841 and it is a great little machine.
Bob
07-24-2004 22:26:31
That looks like a pretty common 2-spool valve, probably a Gresen.
Try the penetrating oil at both ends of the spool. The end that faces up may have gotten water in through the dust plugs, and that is what stuck the spools.
You ask "Should I try penetrating oil, or something else, or try to disassemble the controls?" Well, to disassemble them, you've got to get the spools loose, and getting the spolls loose would pretty much solve your problem, wouldn't it!
David Coe (MD)
07-25-2004 08:20:05
 Re: Re: Rusted/Stuck Loader Controls in reply to Bob, 07-24-2004 22:26:31
Heh, thanks. I'm an external hydraulics newbie -- never been close to one of these 'til now.
Another newbie question: is it ok to bang on the control levers, after the penetrating oil has had a chance to soak in, or am I likely to break them?
Is it safer to bang on the spools directly (if possible)?
Thanks again for the advice.
Bob
07-25-2004 11:25:14
 Re: Re: Re: Rusted/Stuck Loader Controls in reply to David Coe (MD), 07-25-2004 08:20:05
Most likely, the levers are cast iron, and won't take much abuse. Go easy on the spool, also, as it is a precision selective fit on the valve bore. The grooves in the spool, between the "lands" are obviously reduced diameter also, which makes it relatively easy to bend the spool. The end opposite the lever may have originally had rubber caps over it to keep out the elements.
Is there a little block-off plate in there, held in with a snap ring? If you can get in from that end with some PB Blaster, that may be the key to loosening them up. Good Luck!
