Restoration & Repair Tips Board
looking for parts
Matt Klingman
07-14-2004 13:28:38
1952 Fcub. The adjustable front axel was rust. In trying to free it up, the steering arm cracked through where the tie-rod end was attched. I need the left steering arm. I check with the local dealer and local salvage yard with no luck. Any help? Thank you Matt
Matt K
07-14-2004 17:27:53
 Re: Re: looking for parts in reply to Bigdog, 07-14-2004 16:26:37
Thanks for the info. The one I'm looking for had the tapered set bolt. The sset pin must have broken off, because it was drilled through with a split pin on both steering arms.
