Restoration & Repair Tips Board
sealants resistant to gasoline??
JD man
07-04-2004 07:36:30
I'm reassembling a jd "A" after being painted and want to do everything possible to prevent fuel leaks. I've had mixed results in the past with teflon tape. Is there anything better?? Thanks for the help.
John Garner
07-04-2004 21:41:59
 Re: sealants resistant to gasoline?? in reply to JD man, 07-04-2004 07:36:30
JD Man --
Aviation gasket cement (Permatex #3 is the best-known brand) has worked for me for 30+ years, but this type of gasket sealer is alcohol soluble so I wouldn't trust it to resist gasohol.
Otherwise, Loctite Pipe Sealant with Teflon is a wonderful product that I'd expect would do the job for you.
John
