Restoration & Repair Tips Board
Rusty gas tank
Oliver66
06-27-2004 20:42:43
Restored Oliver 44 but gas tank was rusty inside. Doesn't leak but crud fills up the sediment bowl and kills the engine. Any ideas? liner? coating?
Ken
07-05-2004 00:23:09
 Re: Rusty gas tank in reply to Oliver66, 06-27-2004 20:42:43
Yes I agree - I took a couple to a rad shop for cleaning - one a 30 year old tiller gas tank - and the other a gas tank off a Chrysler. Cheap fix and did the trick.
K
Mark
06-30-2004 19:36:13
I used a kit I got from Eastwood on my '73 Vette. It worked great. Has both cleaner and sealer. Very easy instructions to follow although it is a many step process.
Kendall
06-29-2004 15:03:21
Kreem review on ytmag
Kendall
06-29-2004 15:01:31
I used "Kreem" (avaliable from motorcycle shops). Havent used the Por15 but I hear its good.
txblu
07-06-2004 05:55:59
 Re: Re: Rusty gas tank in reply to Kendall, 06-29-2004 15:01:31
I used Por 15 on a Ford tank and had to put an extra inline filter in the fuel outlet.
For some reason, the thing makes water. Don't do anything any different than any other tank on the place and they don't make water. Never did that before. But the tank is sealed. I'll give them that. Gotta open the filter (pull the hose off)and shake out the water (from the filter)about once a month.
Mark
Ron
06-28-2004 19:41:38
Do not follow any advice that calls for mechanical removal of the corrosion. The inside of gas tanks is coated with terne metal, lead and tin I believe, that keeps the tanks from leaking but is easily removed.
Most radiator shops will pressure wash it, treat it with a chemical, and then slosh around a compound made for exactly that purpose. If done properly, it's a lifetime repair.
George H
06-28-2004 14:32:35
Here we've a radiator repair shop that will sand blast gas tanks, then coats them with a liner, a type of which is available at Value Auto Parts, the liner, that is. Good luck.
Logan in S.E. Tex.
06-28-2004 00:31:12
As I have seen suggested on here before, a short length of small chain will also work well to knock lose the crud. just drop it in and shake for all your worth, then remove and rinse out throughly. hope this helps.
msb
06-27-2004 21:28:54
A friend saves bearing balls and puts them in gas tanks and hauls them around in his pick-up truck till the balls clean the rust and crud up.I have never tried it yet so I can't say it does or doesn't work.lol,bob
txblu
07-06-2004 05:52:29
 Re: Re: Rusty gas tank in reply to msb, 06-27-2004 21:28:54
Bad idea. Son tried it with a marble sized ball and knocked out his outlet filter screen ($45).
Mark
Brad_fromTN
06-28-2004 23:02:23
As I recall, a couple of handfulls of small lock washers and some diluted phosphoric acid is what I used on the last tank I did. Left it in for a couple of days and sloshed it around now and then...cleaned up nice. Then lined it with tank sealer and working great ever since.
