Restoration & Repair Tips Board
MF TO(TE) 35 Standard Diesel
Kurtze
06-23-2004 21:35:33
I working on a MF TO 35 w/ a Standard diesel. Tractor was over hauled by someone else b/c it smoked. Afterwards it still smoked. After the first guy gave up it came to me. I have since had the pump and injectors gone through, set the timing by the book, changed filters, fixed fuel leaks, checked compression (300+lbs) and numerous other things. I forgot to mention that it is also hard to start and the smoke is white to light gray, like to much fuel or incorrect nozzel spray pattern. The only thing else I cane think of is the precombustion chambers being crudded up. They were not cleaned when overhauled. I would appreciate any help I would also like to find a good place to buy parts for this. Thanks Kurtze
