Restoration & Repair Tips Board
farmall c axle
MILLARD
06-17-2004 19:06:10
AXLE BROKE BETWEEN HOUSING AND DRIVE GEAR.I HAVE WHEEL OFF AND GREASE SEAL. DOES AXLE COME OUT THROUGH BOTH BEARINGS,OR DO YOU HAVE TO TAKE ENTIRE AXLE HOUSING OFF BECAUSE AXLE IS PRESSED ON. PLEASE HELP ME. THANKS
CNKS
06-18-2004 17:48:33
 Re: farmall c axle in reply to MILLARD, 06-17-2004 19:06:10
The axle is bolted to the bull gear inside the rear end. You have to remove the top cover, or perhaps you can take the pto off and work through the hole. Much easier to manuever with the top cover removed.
