Restoration & Repair Tips Board
Removing Starter 1956 JD60
Glenn
06-11-2004 08:03:45
The starter won't drop out of the case, is it neccessary to remove the flywheel and if so, is that difficult?
The electrical connection was so rusted I couldn't get the bolt free so I am dropping the electrical connector and trying to fee the battery wire down, but it seems to be hung up ...
DonS
06-13-2004 04:01:14
 Re: Removing Starter 1956 JD60 in reply to Glenn, 06-11-2004 08:03:45
Glenn,
You may need to remove the flywheel cover but I wouldn't think the flywheel itself. You have pulled the platform? At least on a late A (47-52) you need to do that to get decent access to the cable if it's routed in the stock position.
Good luck if you have the battery cable exposed everywhere and the starter linkage disconnected it should come out.
