Restoration & Repair Tips Board
massey 44/444
trev
05-31-2004 19:14:54
will a 444 gas 12 volt starter fit a 44-4 ? Some of the genius' say yea, some nay. I havent tried yet but I think it will...Please someone who knows let me in on it...
Randy V(SD)
06-10-2004 14:23:10
 Re: massey 44/444 in reply to trev, 05-31-2004 19:14:54
the difference is that a 444 runs a delco remy starter and a 44 uses a autolite. as far as bolting up, they should because it is the same block. Why would you want to put a 444 starter on a 44? if you need a stock starter I have several used starters for about $50.00 each. If you want to switch over to 12 volt you can use the stock starter without any problems. let me know if I can help. you can call me at 1-605-996-3575
