Restoration & Repair Tips Board
more questions about belarus tractor
lamadon
05-25-2004 16:59:42
my question is what type of fluid goes in the transmission on a belarus? Every thing else is suposeed to be designed to use 30 wt nondetergent oil, hydrolics,steering,and motor. so is it safe to figure tranny as well? I know that in this tractor that the steering and hydrollics have been changed to hydro trans fluid(standard tractor fluid)but Im new to tractors and not a farmer by birth so please be patient with my ignorance in this area.
phil
05-30-2004 18:08:37
 Re: more questions about belarus tractor in reply to lamadon, 05-25-2004 16:59:42
Speaking for the 420a model the service book says;
tranny housing,, final drive housings,front drive axle, and steering wheel bearings use "spirax 90ep,,, Dentax 90,Mobilube C-90, Esso Gear 90, Castrol ST-90, BP Gear SAE-90 EP; SAE-90.
Thats the "foreign" brands of grease listed by the builders, basically a number 90 weight gear oil is required.
Also a "summer" grade of engine oil listed is a HD-30, extra duty SAE-30, good quality diesel SAE-30, and the "winter" grade is shown to be a "20" weight grade of oil, same supplier[s]
Hope it helps.
