Tire cut repair
mike
01-01-2002 16:19:04
I have a nasty cut in the side wall of a rear tire. Bought the tractor as is. It has a patch bolted on the inside and holds calcium ok but the bolts are begining to rust. Is there any better way to repair this. Some way to vulcanize?
Jim T
01-01-2002 17:43:40
 Re: tire cut repair in reply to mike , 01-01-2002 16:19:04
Mike, your tire may be able to be section repaired,but there are limit to this. Must be 2 to 3 inches FROM THE BEAD. Not over 6-8" in length. A patch BOLTED to your tire probably exceeds these limits. Have a local tire man look at it, he can point you in the right direction. Jim T
Bill
01-01-2002 17:16:13
I would like to see a good remedy to this problem too. thank-you!
