Restoration & Repair Tips Board
What sheet metal to buy
Ryan
05-13-2004 11:18:08
I was thinking of buying some sheet in the future and I was wondering what you think a good thickness would be to buy? I am wanting some to fix fenders and possibly some day for forming.
Ryan
Chester
05-13-2004 15:33:44
 Re: What sheet metal to buy in reply to Ryan, 05-13-2004 11:18:08
18 Ga ( ungalvanized ) is what I keep on hand for body repairs and misc tool box projcts etc, etc.
Bought a bunch of smaller sheets at the scrap yard a few years back and wiped them down with old motor oil, to keep them in good shape, in storage. It can be easily bent in a brake and forms satisfactorily in shop made dies. Good for most sheet metal projects.
randy morgan
06-06-2004 21:18:48
 Re: Re: What sheet metal to buy in reply to Chester, 05-13-2004 15:33:44
trust me, if you use anything heavier than 24 gauge, you will need electric cutting tools. if you're not used to cutting metal, those snips will blister you're hands quick! there is a metal that is called paint grip. it has no galvanized coating. it still needs to be prepped the same way any bare metal does. plus you don't have to worry about zinc poisoning. good luck
Rusty Jones
05-19-2004 17:31:40
In the auto body shop trade, we used 22 guage sheet tin, sometimes 24 G. Although you may need the heavier guage for tractor parts! Remember, the lower the guage number, the heavier/ thicker the tin. And, getting paint to stick to galvanised tin is sometimes a problem, although it can be done, with proper treatment! And, there is a better grade of sheet tin than the low priced stuff--it seems to work better for forming, etc. you'd have to ask about it. Been 10 years since i left auto body! Also the heavier the metal, the harder it is to cut, unless you have really good shears, or an electric shear on an electric drill powered machine. That's the one with the 2 lower teeth and 1 upper tooth, that cut with a scissor action. RJ
