Restoration & Repair Tips Board
No International 2424 Hydraulic Pressure
Heywood Becker
05-13-2004 04:48:14
My International 2424 Loader/Backhoe was down for repairs, and when put back together, the hydraulics will not come back. New fluid added to correct level, and diverter valve checked and cleaned [I was advised that dirt can cause it to stick and prevent fluid from circulating]. The various backhoe components move just a bit, and very hesitantly. Suggestions, please?
Ben in KY
05-13-2004 08:36:45
 Re: No International 2424 Hydraulic Pressure in reply to Heywood Becker, 05-13-2004 04:48:14
Does you 2424 have a front crank mounted pump for the bucket and hoe ? Sort of sounds like it is sucking air or the pump is not primed. Does you rig have a 3 point liftbox under the seat ? If so does it work ?
Heywood
05-13-2004 10:23:06
 Re: Re: No International 2424 Hydraulic Pressure in reply to Ben in KY, 05-13-2004 08:36:45
Responding to BEN in KY:
Yes, front-mounted pump shaft-driven from crankshaft.
No, there are no lift arms. The backhoe mounting would seem to have obviated them.
The transmission-reardrive reservoir holds the "hydraulic" fluid which bathes everything, including the hydraulic system.
Ben in KY
05-19-2004 12:01:11
 Re: Re: Re: No International 2424 Hydraulic Pressu in reply to Heywood, 05-13-2004 10:23:06
I would try pulling the suction line loose from the front pump and filling with Hytran or UTF, to try to prime the pump. There is a long big suction line there. Also there might be a screen on the tranny end of your suction line that might be haired over.
