Restoration & Repair Tips Board
crack in final drive body
Steve in Tex
05-05-2004 12:29:17
I took off the pivot assembly that holds the swinging drawbar looking for an oil leak and found that @ some point this assembly was knocked off the tractor. a long crack where two of the three 1" bolts ,was welded and an 8" crack (crossways) about 6" behind the bolts was welded. Oil leaks several places along these welds .I was thinking split tractor, pull trans. and maybe cleaning and using Por 15 on the inside? any help GEATLY APPRECIATED !!! Thanks!
Kendall
05-06-2004 15:03:24
 Re: crack in final drive body in reply to Steve in Tex, 05-05-2004 12:29:17
You might try brazing over the welds. This would fill the small crack.
steve in tex
05-08-2004 10:15:24
 Re: Re: crack in final drive body in reply to Kendall, 05-06-2004 15:03:24
Thanks, do you mean braze over welds underneath tractor, or dissasemble and braze inside the casing?,Steve
