Restoration & Repair Tips Board
Tractor Paint
Jake Stage
04-29-2004 09:35:50
I'm getting ready to paint a John Deere 630. I've been asked to make it look really good for a small price. Normally I work with Automotive epoxys, but that is out of my client's price range. I was wondering if any one out there has any tips on using a cheeper paint ($20-$70 to the gallon) to make a tractor look good. Primer advice would be very helpful as well.
CNKS
04-29-2004 12:40:14
 Re: Tractor Paint in reply to Jake Stage, 04-29-2004 09:35:50
There is a world of difference between $20 and $70 paint. Suggest you try PPG's Omni line, or DuPont's Nason line. These paints will push $80-$90 a gallon with hardener. Sherwin Williams and Martin Senour have similar paints. Or, for less money you can get Deere's synthetic enamel from a John Deere dealer--that's the cheapest you should go. Use epoxy primer on everything, not the primer JD has, unless you put it over the epoxy. As you know, it is best to stick with one brand. Paint sold by farm stores (TSC, etc) will fade rapidly. Using the Omni line, you will use maybe $150 worth of paint, if you buy it by the gallon, maybe less depending on what your supplier charges -- perhaps you can use the leftover paint for other projects.
