Restoration & Repair Tips Board
gen/regulator problem
polk crawler
04-26-2004 20:57:17
Steve is right; just been through that with 6v system and cut-out contacts welded together, result of hooking batt up to negative instead of positive ground.
Check those contacts with cut out; get them apart, dress them a bit with file or emergy cloth, blow out with compressed air, hook batt to postive ground...should be OK.
PC
Dave in S MN
04-27-2004 16:27:09
 Re: gen/regulator problem in reply to polk crawler, 04-26-2004 20:57:17
Do have one question:
Would this also cause the tractor not to show a charge?
-Dave R
polk crawler
04-27-2004 19:11:22
 Re: Re: gen/regulator problem in reply to Dave in S MN, 04-27-2004 16:27:09
If ammeter is wired in correctly, with engine rpm up, if voltage regulator or cut out contacts are stuck together ,batt should be getting a charge, 6-7 amps, more if the batt is low; if no charge shows I would be suspicious of the voltage regulator ( or whatever does the same function) or the ammeter. Hope you find the problem and answer here or in other followup posts. PC
