Restoration & Repair Tips Board
ammeter for 6V system
polk crawler
04-11-2004 07:01:14
Ammeter for the 6V system does not register tho the needle is NOT stuck; two terminals on back; what wires should be attached ( from where and to where) to the two terminals to get a batt charge reading? test shows generator is putting charge out, up to 7.5V,registers OK at the battery but ammeter shows nothing.
Thanks for any leads.
PC?
txblu
04-11-2004 07:47:11
 Re: ammeter for 6V system in reply to polk crawler, 04-11-2004 07:01:14
Draw yourself a picture. The ammeter is between the battery terminal and everything else electrical in the system EXCEPT the high current starting ckt. Therefore your elect ckt will probably be like this:
Big wire from batt hot (the side not connected to the chassis; polarity doesn't matter ) to one side of the starting solenoid (big terminal). From there a wire goes to one side of the ammeter and everything else electrical comes off (either directly or indirectly) the other side of the ammeter. That way the ammeter measures batt input (+ when charging) and output (- ign key on, lights on etc.). If you don't like the direction the needle is moving, swap the wires at the ammeter and it will deflect the opposite direction; i.e. charge will be - rather than +. May choose to do that on + grounded system; and then you may not. To me it is + always as you are ADDING energy to the battery (regardless of the polarity hookup to the tractor) which is a +.
The other side of the starting solenoid (other big wire) goes to the starter terminal. It's that simple.
txblu
polk crawler
04-11-2004 12:59:13
 Re: Re: ammeter for 6V system in reply to txblu, 04-11-2004 07:47:11
TXBLU:
Thanks for making it simple; didn't seem logical current would not flow through the ammeter if wires from somewhere were attached only to one terminal (toward starter solenoid).
Appreciate your help. Thanks.
PC
txblu
04-11-2004 15:07:08
 Re: Re: Re: ammeter for 6V system in reply to polk crawler, 04-11-2004 12:59:13
Any time buddy. I find that if I map out complex problems or look at them as simplistically as possible, there usually exists a simplistic solution. Also, I try to stay functionally alert. What is the function of this, how does it accomplish that, what happens if it doesn't, and what could something else do to prevent this function from happening.
best,
txblu
polk craw;er
04-12-2004 15:23:36
 Re: Re: Re: Re: ammeter for 6V system in reply to txblu, 04-11-2004 15:07:08
TXBLU";"One more time, please? Followed your instructions about wiring ammeter; at high rpm ammeter registers proper voltage flowing TO the battery; hit mag ground switch, engine stops, immediately ammeter needle swings all the way to the left on the dial indicating discharge? Switched wires to and from ammeter and no needle movement.BTW: system is 6V, postive ground. What have I missed this time? If discharge is occuring cannot leave battery cable(s connected when crawler is not in use. PC
txblu
04-13-2004 09:56:47
 Re: Re: Re: Re: Re: ammeter for 6V system in reply to polk craw;er, 04-12-2004 15:23:36
Depending on your generating method, you may have something different; i.e. dc gen vs alt. Since you said 6v, I'd assume a dc gen.
Seems the dc gen windings are remaining hooked up to the batt term, not removed when you turn the key off. In an alt system, you can connect the output of the alt directly to the ammeter as the diodes in the alt block this discharge.
So what has to happen is the the gen output to the batt (via the ammeter) has to also be via something else and this has to be your ignition switch as there is nothing else on the tractor to do the job.
If you have an old Motors Brand Auto Manual (Blue one) that has a generator hookup you can see what needs to be done. There is also the voltage regulator to include in the wiring and you need to look at a diagram, not words. Otherwise, a wiring diagram of a tractor (any tractor to get the idea) using a dc gen should work. Polarity is not a problem if you see a diagram with a neg gnd; which I doubt as I believe the 12v system (for xixtr radio's and other things) is when they went to the neg gnd (for convenience). You are looking for hookup methodology.
I agree. If the gen is connected to the ammeter, when you turn the engine off it will bleed the batt dry.
txblu
polk crawler
04-13-2004 10:44:19
 Re: Re: Re: Re: Re: Re: ammeter for 6V system in reply to txblu, 04-13-2004 09:56:47
Failed to read both your messages; FYI: engine is started by momentary (push botton) switch which activates the solenoid near instrument panl,engages starter etc. There is NO ignition key etc to turn off or on ( as on my OC46). Plugs get fire via the mag when starter turns engine over; Engine will continue running even if battery cables are disconnected; engine is stopped by grounding the mag out. All battery is needed for on the OC3 is to power the starter. Once engine is running battery's work is done, then accepts charge per specs.
AM sure you know all this but want to be clear about elec hookup as it exists at the moment ' this includes wire from BATT terminal on voltage regulator to ammeter; wire from other side of ammeter connects to where large batt cable from neg batt terminal connects to solenoid..cable from other side of the solenoid goes directly to the starter; so charging current flows through ammeter, then via solenoid terminal to the battery (neg battery terminal as it is a Pos ground system)
Hope my explanation doesn't add to confusion; I'm trying!
Thanks
PC
txblu
04-14-2004 08:52:44
 Re: Re: Re: Re: Re: Re: Re: ammeter for 6V system in reply to polk crawler, 04-13-2004 10:44:19
I didn't know you were on a magneto. Has been a long time since I visited a voltage regulator, but I'm going to say that it is why you are getting current when you shut down the sytem. ----- ----- ----- ----
Relay contact sticking in the regl. is the guess.
Guessing again until I get to the books. This is probably the senario:
1. starter engine which rotates magneto which generates electrical energy via electromagnetics. This energy is controlled by ignition points to get high voltage out of it when and where you want it.
2. The engine fires and starts up, rotating the armature of the generator. This generates a dc voltage (in the armature) which is sent to the voltage regl ("A" contact as I recall) which pulls-in the contacts within the regl(closes them) and connects the field (F) winding of the generator to the battery (via the ammeter)which starts charging the batt because a voltage is induced in the field, by rotation. This volage is directly proportional to rotating speed and is why generators were notorious for not charging at low rpm's. They had to spin fast enough to generate more voltage than was on the battery to push energy into the battery.
The voltage regulator controls charging current to the battery and monitors voltage (regl adjustments at factory). ----- ----- ----- ----- ----- ----
When the engine is turned off, the armature stops rotating and the voltage on the regl (A) disappears which should cause the regl contacts to drop out. Apparently they don't (pitted and stuck together---welded). Since the generator Field winding is shorted to the gen chassis (internal to the gen), you have a direct short (a little resistance) to chassis from the battery hot term and the ammeter pegs discharge.
I'll verify authenticity of what I have said tonight and if any errors, will clarify.
Mark
txblu
04-13-2004 10:01:34
If you can't find something,and have the time, post back and I'll go dig up a diagram and try to talk you thru it.
Better yet, give me your email and I will scan it and email it to you..... once I find it; may be a day or 2.
polk crawler
04-13-2004 10:25:41
 Re: Re: Re: Re: Re: Re: Re: ammeter for 6V system in reply to txblu, 04-13-2004 10:01:34
TXBLU:
Thanks a bunch; will respond as you suggest. sure appreciate your input and willingness to be of help.
PC
txblu
04-14-2004 05:50:49
 Re: Re: Re: Re: Re: Re: Re: Re: ammeter for 6V sys in reply to polk crawler, 04-13-2004 10:25:41
I'll check email when I get home this afternoon and look up a diagram.
Bob
04-14-2004 07:51:58
 Re: Re: Re: Re: Re: Re: Re: Re: Re: ammeter for 6V in reply to txblu, 04-14-2004 05:50:49
On of the diagrams on Bob M's site oughta do the trick for just about any old tractor.
mj
04-15-2004 10:26:03
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: ammeter fo in reply to Bob, 04-14-2004 07:51:58
Bob, I have a question for you on the schematics on your album page. Please e-mail me (skipjack at montrose.net)
Thanks, mj
polk crawler
04-14-2004 11:16:13
Bob: Thanks for the diagrams, #5 fit; will print it out for my file.
Problem was stuck relay points in the voltage regulator which was creating a short draining the 6V battery when the engine was shut down.
Everything on the OC3 working as it should.
Thanks for your response and help. Much appreciated.
PC
polk crawler
04-14-2004 10:25:49
Bob: Join the game!! Diagram #5 is the right one and my OC3 is wired accordingly. Now..why does ammeter show negative needle position when mag is grounded, engine shut down, and battery cables all connected (6V pos ground)?Test at batt shows 7.5V charge with engine running. I'm stumped. Is the regulator faulty...new 8/2002? Just as soon correspond by e-mail and get off the discussion board.
Appreciate your interest and help.
PC
Bob
04-14-2004 11:05:23
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: ammete in reply to polk crawler, 04-14-2004 10:25:49
P.K. ...
The "cutout" points are welded together. Even if you have a voltage regulator, rather than a cutout, one of the units inside is the "cutout relay".
This may have happened because somewhere along the line the battery has been installed with the opposite ground polarity of what it was when the regulator was first installed, without re-polarizing the generator before restarting the engine.
If you are the adventurous type, you can remove the cover from the voltage regulator and look for the unit with the heaviest contacts. This is your cutout relay. Pry the stuck points apart and touch them up a little with a point file. give them a puff of compressed air, if available, to remove and debris. WARNING>>> the unit may work just fine, or continue to stick. If it sticks again, the thin silver coating on the points is probably worn through, and it's best to replace the regulator, because when it sticks and kills the battery, there is a potential to burn out the generator, or start a wiring harness fire.
If you need to replace the regulator, make sure that the battery ground polarity is the way you want it to be, and then, after installing the regulator, polarize the system by using a jumper wire to connect the "BATT" and "A" terminals for a couple of seconds, before starting the engine.
From then on, when re-installing the battery, always connect it up the same way.
polk crawler
04-14-2004 16:46:17
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: am in reply to Bob, 04-14-2004 11:05:23
Bob: Think we have flooded this board long enough about the ammeter etc. Discovered the problem was as you described it.
So far no more sticking of the points but if the problem happens again I willIknow where to check.
Thanks a bunch for your counsel and help.
PC
txblu
04-14-2004 10:11:35
OUTSTANDING! My bet is #5.
Thank you sir.
txblu
polk crawler
04-14-2004 10:30:08
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: ammete in reply to txblu, 04-14-2004 10:11:35
TXBLU:
Right about diagram #5. Same question I asked of Bob: OC3 wired accordingly. but why does ammeter needle fall completely to left indicating discharge when engine is shut down?
I checked connections between regulator and generator and they are correct. Is the regulator faulty..new 8 /2002 but who knows.?
PC
polk crawler
04-14-2004 11:13:20
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: am in reply to polk crawler, 04-14-2004 10:30:08
Mark: Call off the dogs, coon has been treed, so to speak. Between my asking about the regulator and your suspicion about relay points being stuck, the hunt is over!
Found points in the relay connected to GEN side of the regulator stuck, not hard but not free; pried points apart, used a little emergy cloth to clean up the contacts, reinstalled, made all connections..no negative on ammeter, full charge with engine running.
Learned a valuable lesson in response to your initial follow-up about simplistic solutions to fairly simple problems. A process of elimination in this case..wiring correct so problem somewhere else...and it was.
Thanks a bunch for your guidance and help.
PC
txblu
04-14-2004 13:15:08
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re in reply to polk crawler, 04-14-2004 11:13:20
I am tickled to death for you. What a deal. Besides getting the good feeling getting to help you, I also got Bobs posting of all those fabulous schematics. That is payment enough and then some in itself.
Mark
polk crawler
04-14-2004 16:41:57
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re in reply to txblu, 04-14-2004 13:15:08
Mark: Just one more question; where are you located? I am in Oregon, 20 mi W of state capitol. Salem.
What a "gooder" this has been! Glad we shared it.
PC (Leon)
txblu
04-16-2004 05:49:42
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re in reply to polk crawler, 04-14-2004 16:41:57
Half way between Dallas and the Okie line.
Enjoyed it too and so glad it worked for you.
Mark
