Restoration & Repair Tips Board
hydrastatic transmission flush?
Mac
04-09-2004 15:50:57
I've had a Cub Cadet 105 for about a year. (I'm also new at working on these.) It had an oil filter on the transmission. I took it off and removed the drain plug nearest the filter and about a quart of black oil drained out. I then removed the plug from the bottom of the differential and drained what looks like standard gear oil. Should I flush the transmission with something? I now have a hydra filter and 8 quarts of hytran. Does hytran lubricate both the pump and the differential, and if so should I fill through the plug on the back of the tractor? Thanks for your help.
