Restoration & Repair Tips Board
polariization
polk crawler
04-08-2004 08:44:39
Have taken the generator off the OC3 in for a rebuild; somewhere read and copied instructions about polarizing but can't locate them. Would appreciate step-by-step instructions to follow after the generator is reinstalled.
Thanks for any help. PC
mj
04-08-2004 15:09:51
 Re: polariization in reply to polk crawler, 04-08-2004 08:44:39
Click the link....the last paragraph on the page is the meat of it.
polk crawler
04-10-2004 21:17:59
 Re: Re: polariization in reply to mj, 04-08-2004 15:09:51
MJ:
If you are still out there,any idea what to do about an ammeter that does not register? Got the generator going, putting out proper voltage charge at high rpm, but the needle on the ammeter does not move; took it out, cleaned terminals but still no life in it. Maybe it is not wired correctly? Needle wiggles and is not stuck.Come back on e-mail if you wish. Thanks
PC
polk crawler
04-08-2004 15:35:32
Thanks for the info. Obviously my "senior moments" are getting longer , more frequent, etc.
Seems like I ought to just remember how to do the polarization but age doesn't always help.
Again, thanks for the referral. \
{C
mj
04-08-2004 20:52:20
 Re: Re: Re: polariization in reply to polk crawler, 04-08-2004 15:35:32
I heard all of THAT! Take comfort.....you're not alone!
polk crawler
04-09-2004 07:29:19
 Re: Re: Re: Re: polariization in reply to mj, 04-08-2004 20:52:20
MJ: Think there is a permanent cure for the problem but prefer to continue the senior moments than terminate and never have to forget again.
Have a gooder.
PC
