Restoration & Repair Tips Board
needs choke to run
john watson
04-05-2004 11:16:05
Hi fellas need some help waiting on manual for tractor so dont know what carb settings should be
tractor runs but only with the choke shuts down as soon as i close the choke the carb is a marvil
with the numbers 361 and 52 on it
i know i have to rebuild the carb so any help with a good parts store would be great i live in florida now but come from england so still have good contacts there that could get my parts if needed
Newman SW Virginia
04-17-2004 17:43:29
 Re: needs choke to run in reply to john watson, 04-05-2004 11:16:05
Your local NAPA store will or can get a lot of the things you will need. Over here in Southwest Virginia NAPA had my carb kit on the shelf but it did not include the float and they could not get the float. Terry
mj
04-08-2004 11:29:58
Try this: Take the low-speed needle out of the carburetor and give the hole a shot of carb cleaner followed by a short blast of high-pressure air from a rubber-tipped blowgun then screw the needle back in all the way until it bottoms( EASY on the 'bottoms'!) then screw it back out a turn and a half or 2. That should get it started and running right if the trick worked. Adjust the idle speed, tweak the mixture and you're good to go.
Loren
07-17-2004 11:21:03
 Re: Re: needs choke to run in reply to mj, 04-08-2004 11:29:58
Just be warned that a big shot of air can implode the floats.
txblu
04-11-2004 07:54:22
If that doesn't work, remove the carb, dismantle it carefully (might be able to save your gaskets), remove high and low speed needles (keeping track as to how many turns they are adjusted out from bottomed) and do the whole carb as mj suggested.
I use Berryman't spray chem tool (and then the air, several times) as it has great ingredients to melt varnish and that's what usually plugs fuel metering holes in carbs and that is your problem. You aren't getting enough fuel to your engine. Then put her back together and should be a go. Just did a lawn mower this wk end. Wouldn't start (did have spark). Popped the carb off, shot her up, aired er out, put her back together and presto.....purred like a kitten.
txblu
