Restoration & Repair Tips Board
Super A Farmall
Joe Harris
03-22-2004 10:12:24
I need to know how to get the sleeves out of the block. I have tryed just about every thing to get them out. THANKS JOE
Brad
03-23-2004 18:56:29
 Re: Super A Farmall in reply to Joe Harris, 03-22-2004 10:12:24
I pulled the sleeves out of my Farmall A back at Christmas time but I had to press mine out with a shop press. I had bought a home-made sleeve puller but those sleeves did not want to come out, since they had been sitting tight since 1946. I resorted to turning the block over, sticking it under the shop press and pressing them out using the plate of my useless sleeve puller. Once the sleeves popped loose they moved right on out. Of course doing it this way means removing the block from the tractor, but I was rebuilding everything anyway. I think that a professional sleeve puller, like an OTC, would have done the trick (very expensive). I tried the parts stores for a loner or rental and nobody had one. If you live in real tractor country someone might have one for loan.
J.H.Harris
03-23-2004 20:13:53
 Re: Re: Super A Farmall in reply to Brad, 03-23-2004 18:56:29
I think the owner of the tractor has located a puller from a friend. Thanks for the help.Joe
