Restoration & Repair Tips Board
Tractor Tires
LKinney
03-10-2004 11:29:25
When do rear tires absolutely have to be replaced? Dealer told me I have weather checking & dry rot. Tractor will have minimal use. Owner can't afford new tires. Does tire putty work? Or Miller paint? Thanks for any help.
52BMAN
03-12-2004 09:21:33
 Re: Tractor Tires in reply to LKinney, 03-10-2004 11:29:25
I have some tire putty from Miller Tire I will sell to you for half price. It cost me $40. Email me if interested. Mark
52BMAN
03-12-2004 09:25:02
 Re: Re: Tractor Tires in reply to 52BMAN, 03-12-2004 09:21:33
On second thought, call me if interested in the tire putty. 515-228-3054. Thanks
John
03-11-2004 07:01:35
When the air comes out of them and no longer will stay in them, then you will know it is time. How long an old, cracked tire will run depends on many things. If they are loaded up with wheel weights and heavey 3 point impliments, they won't last long. Run them till they go flat but know in the back of ur mind they will have to be replaced one day and start setting aside a little cash.
Bigdog
03-10-2004 12:58:53
If it's a working tractor and appearances don't matter, you can run them until they won't hold air. When the dry rot reaches the point that the lugs or sections of sidewall start to peel off, they're gonna fail when it's least convenient. Using tire putty or paint will retard the deterioration, but maybe it will make them last until affordable replacements can be obtained.
LKinney
03-11-2004 06:17:43
 Re: Re: Tractor Tires in reply to Bigdog, 03-10-2004 12:58:53
Bigdog, thank you for your input. You said they can be run until they won't hold air, these tires have tubes, so what exactly do you mean? I know absolutely NOTHING about tractor tires. Thanks!
Ed
03-11-2004 15:34:30
 Re: Re: Re: Tractor Tires in reply to LKinney, 03-11-2004 06:17:43
When the tube are exposed and get holes in them. You'll know when to get new tires when you are running on flats or the rims.
