Restoration & Repair Tips Board
starter button
mcray
03-01-2004 14:06:54
how do i remove my starter button an can i repair as of its quit thanks mcray 8n 52 ford
Bob
03-01-2004 20:54:26
 Re: starter button in reply to mcray, 03-01-2004 14:06:54
You have to remove the transmission cover, as there's a nut on the bottom of the switch, under the tranny cover. Have you verified the switch is bad by making sure the tranny is in neutral, and the clutch depressed (so you don't run yourself over), and shorting the terminal on the switch to ground?
mcray
03-07-2004 12:36:12
 Re: Re: starter button in reply to Bob, 03-01-2004 20:54:26
thanks. idid test now ican look at itto see if i can fix or replace.mcray
