Restoration & Repair Tips Board
TRUE turpentine
old
02-06-2004 19:26:10
Here it is right off the Can
Gum spirits of turpentine because of its unexcelled solvency it is the premium thinner for oil based paints etc to produce the desired viscosity for improved flow leveling, coverage and penetration. This is what you use to unstuck a stuck engine.
john
02-08-2004 18:26:07
 Re: TRUE turpentine in reply to old, 02-06-2004 19:26:10
I pulled the head off and the walls have medium rusr.will ihe turpentine and a rotary wire brush clean the rust or should another fluid be added????? Thanks ....John
old
02-08-2004 19:03:02
 Re: Re: TRUE turpentine in reply to john, 02-08-2004 18:26:07
Turpentine will clean most of it off with out the brush, it cleans rust really well
john
02-08-2004 19:22:56
 Re: Re: Re: TRUE turpentine in reply to old, 02-08-2004 19:03:02
Thanks....I will tr and find the true turpentine..... ...John
old
02-08-2004 19:35:38
 Re: Re: Re: Re: TRUE turpentine in reply to john, 02-08-2004 19:22:56
Anymore its getting hard to find, I had to go to 5 places before I found any and then I brough all they had. I guess I will have to start looking again soon since I only have 1 gallion left and two engines in need of it. By the way I found out about turpentine from an old man that makes me look young, hes 90plus
Glenn in PA
02-11-2004 19:13:38
 Re: Re: Re: Re: Re: TRUE turpentine in reply to old, 02-08-2004 19:35:38
Believe it or not, I found the "old" stuff at Wally World. One of the few things there from USA, not China....
old
02-11-2004 19:57:15
 Re: Re: Re: Re: Re: Re: TRUE turpentine in reply to Glenn in PA, 02-11-2004 19:13:38
That was the first place I looked and they didn't have it, but not all of them have the same stuff.
