Restoration & Repair Tips Board
Rusty gas tank Farmall B.
Jim Sorrell
01-19-2004 18:02:28
Does anyone know how to remove rust from a gas tank? Mine is rusted inside pretty bad.
Gordon
03-19-2004 09:11:52
 Re: Rusty gas tank Farmall B. in reply to Jim Sorrell, 01-19-2004 18:02:28
Go to your local body shop supply house. Get a metal prep solution. Most of them have phosphoric acid as the active rust removal ingrediant. Use it stronger and longer than the directions call for as it is intended to remove slight surface rust residue after panel sanding/grinding. I use a product labeled "DX 579" made by PPG.in Strongsville OH. Note. EVERYTHING you sand, blast, or clean should be treated with this stuff prior to primer. Insure you don't allow tiny rust pits to remain. It's like a cancer under there and you want to "get it all" just like the real thing!
kwright
01-28-2004 17:18:46
I recondition vintage motorcycles for a hobby (and sometimes a little profit). I have to deal with rusty fuel tanks all the time, and I've tried just about every option there is - I think.
My personal favorites (based on actual experience over the years):
POR-15 Fuel tank restoration kit. A bit pricy perhaps, but absolutely superb. You MUST follow the directions to the letter, but if done correctly, it's a great solution.
Electrolysis � essentially a mixture of soda (not baking soda) and water is placed in the tank, a battery charger is connected to a sacrificial anode and grounded to the tank, and the rust migrates to the anode. Can take up to a couple of days, depending on the level of the rust. This really does work and is actually my method of choice these days.
I�ve tied the mechanical processes, i.e., lots of small hardware such as nuts and bolts, and shake it around, sand blasting, and others, but I prefer the two methods I just identified. Especially if the intent is to preserve the exterior finish of the item.
bryan
01-26-2004 13:04:09
Here in my shop , i use Lime Away ,or CLR for cleaning some carb and gas tanks . Won't work on all , but does pretty good job on some ,,worth a try .
Nolan
01-20-2004 05:51:22
Vinegar is a dandy derusting chemical.
Joe
01-19-2004 22:39:13
Yes, go to www.POR15.com and they have gas tank cleaner and sealer that works great. I used it on a F150 tank.
ELW/TN
01-19-2004 20:16:10
Yah. Pressure washer or car wash can knock out a lot of crud. Then put in some gravel or crushed limestone with some kind of liquid (water, gas, solvent, etc)and shake it around to remove a lot of the rust. You can get stuff to coat the inside of your tank after that.
Also, some radiator shops have a way of cleaning them out and they use something to line the inside. This helps plug up any pinholes you may have.
old
01-19-2004 20:13:30
I use turpentine to clean tanks, but I have also heard of some stuff you can find at motorcycles places for that also been told it has a cleaner and a sealer also but I don't know what its called
