Restoration & Repair Tips Board
ford 841diesel. fuel in engine oil
James
01-16-2004 01:58:59
Cranks and runs very good. checked under valve cover and haven,t seen any sing of leaking fuel at injectors or return lines. small return line coming out of cyl head spurts fuel out when you throttle up,and seems to be hot. is this port open to the head gasket. if so could a bad head gasket be the problem. is this problem the fuel injection pump shaft seal. has a roda master pump. can the seal be replaced witout having to rebuild the injection pump.
old
01-16-2004 08:27:16
 Re: ford 841diesel. fuel in engine oil in reply to James, 01-16-2004 01:58:59
Its probabply the shaft seals, and yes they can be replaced with out rebuilding the pump just make you you have it timed when you pull the pump there should be a little window on the side of it to line up the timeing marks so you can pull the pump with out messing up on timeing
