Restoration & Repair Tips Board
marvel schriber carb
jim
12-29-2003 06:03:09
I HAVE AN OLD CARB THATS BEEN SITTING AROUND. WHATS THE PROPER WAY TO CLEAN IT THROUGHLY, BEFORE I REBUILD. THANKS
tom
01-07-2004 13:57:21
 Re: marvel schriber carb in reply to jim, 12-29-2003 06:03:09
Jim,
using the one-gallon bucket is fine, it comes with a basket so you can suspend the parts...as noted, use eye-wear and gloves...
ALSO, very important, when you soak the carb, make sure any of the soft-parts [seals, felt-pieces/etc] are removed first or you have replacements...the cleaner will almost dissolve them...
good luck,
tom
Jim
01-03-2004 07:20:27
Put the parts in a metal can--not plastic--to clean. When I bought my can of cleaner, NAPA had a one gallon paint can that works great. Be sure to put the lid on tight. Don't splash the parts when put in the cleaner-tough on skin and eyes!! Good luck.
John S.
12-29-2003 19:12:06
NAPA sells a 5 gallon dip bucket that you can soak the carb in. It works the best that I have ever seen. Plus you dont take the chances you take with sprays plus you can allow all parts to soak and eat away foreign matters. As a caution though please follow directions and warnings as a safety precaution because its very caustic.
