Restoration & Repair Tips Board
Tires
Jim from Ill
12-24-2003 06:34:36
Is there any trick to saving mildly weather checked rear tractor tires? I am getting tired of always buying new tires and the tractor I have now to restore has tires that aren't to bad. They do not appear to have had fluid in them and the sidewall looks ok. Thanks for any help.
Stretch_03
01-07-2004 20:10:16
 Re: Tires in reply to Jim from Ill, 12-24-2003 06:34:36
Jim,
I'm not any kind of tractor expert, but probably like you I've owned cars and trucks all my life.
If I wanted to keep my tires as new as possible on a truck, I'd keep them aired to the correct psi and I would drive regularly and normally. And I'd rotate them every 7500 miles.
If my truck did alot of sitting around (like a tractor might...sometimes), I'd make sure the vehicle was stored out of the weather. I'd jack up the rear end just a little and lower the air pressure in the tires.
If you use the tractor occasionally and don;t have a compressor handy where you could just air up the tires in a few minutes before use, then at least keep the tires out of the sun and weather extremes.
That's what I'd do for regular auto tires anyway.
Jim
12-25-2003 05:30:19
Millers sells a tire black that you can spray on or brush on. It is a water base and works well.
