Restoration & Repair Tips Board
fix that cutout relay
Rick
12-20-2003 14:48:38
My 40 Ford 9N has a cutout relay and no regulator. After going thru 2 new cutout relays that would not work, I modified one to accept a bridge rectifier from Radio Shack. $3.25 and a little shop time and all is fixed. I posted a couple of pictures on Parts and Pieces to show how I did it. Works perfectly. How do you know a cutout relay is bad? First, if the gen is good, then when the tractor is running you should have + on the ammeter and when the tractor is off, the ammeter should read 0, not in the minus. Is your battery fine and then the next day it is dead? Its likely the cutout relay.
