Well, it isn't an enhancement so much as a copy of something we saw that worked. The pickup is crucial. I have never seen the pickup in commercial siphon cabinets, but they suck. The pickup in my little portable siphon is a tube, with a hole drilled just above where the sand level is, which confused me. Turns out, sucking sand up a tube is very hard, and gets harder the further down in the sand it is. Just like it's easy to breathe through a snorkel, until you get underwater. Then, it gets really hard if you try to submerge as far as it will let you. The trick is to get a siphon tube that essentially picks sand up at atmospheric pressure, not whatever the pressure is several inches down. That's what the little hole is trying to do, but doesn't work well. Get a 1/2" OD tube as a pickup. Put it inside a tube that's bigger, say 5/8 or 3/4 ID. Make sure they are even on the pickup end, the smaller tube should stick out the top of the bigger tube enough to hook up your flexible pickup hose. Actually, 3/8 OD and 1/2 or 5/8 ID might work better, whatever. Mine are held together by simply crimping them in a set of bolt cutters JUST ENOUGH that they stay together. You want to distort the inside of the pickup tube as little as possible. The commercial version I did see had a fancy little crimp that I couldn't duplicate. A pop rivet might work as well. My tubes still rattle a lot, which is fine. That's it! Sucks sand like there's no tomorrow. Having it loose inside the cabinet is nice, too. I use it to scrape the sand down into the bottom of my hopper and stick it right in the middle. As I mentioned, a clog is cleared instantly. If you're watching carefully when you "backblast" it, you can usually see the piece of RTV or whatever caused the plug and quickly pick it up. My gun is the cheapo with the trigger on it. I have to rebuild the trigger every couple years, a triggerless gun and a footpedal would work better. However, it's the increased flow of sand due to a better pickup that makes all the difference. If I muddled things up, give a shout, I'll try to re-explain it. Better yet, I fixed my digital camera yesterday, maybe I'll just go take a pic and email it to you if you want. Tools
