Restoration & Repair Tips Board
Timing Hercules IXA5 Engine
Kolf Randy
12-10-2003 07:30:42
Hi There,
I have a generator with a Herculess IXA5 engine.
The problem is I lost the timing when I rebuilt my water pump.
How Can I set the Timing?
I can find the DC mark on the flywheel but how do I set the distributor?
Distributor is a Fair Banks Morse model FM XE4A14B
Please Help me
Randy
Glen in TX
12-20-2003 12:18:24
 Re: Timing Hercules IXA5 Engine in reply to Kolf Randy, 12-10-2003 07:30:42
Is it a Kohler generator? I have a book someplace for Kohler and will look later to see what it shows. You should be able to get your engine on #1 compression stroke. #1 cylinder being toward the radiator/fan end. The mag should be positioned with the dist. rotor lined up with the upper right hand terminal. If this doesn't let the impulse lugs line up then try the upper left hand terminal position.
Randy Kolf
01-11-2004 12:16:03
 Re: Re: Timing Hercules IXA5 Engine in reply to Glen in TX, 12-20-2003 12:18:24
Hi,
I still was not able to start the engine.
due to yearend activities I havenot tried but now everything back to normal I am trying again. I am to sure if it ia a kohler generator. on the engine it says HERCULES
I all ready found the position on the death center the problem I have is withthe distributor
Fair Banks Morse I cannot figure out how it works since it doen not work like ordenairy distributors.
Any idea
Thanks
Randy
Glen in TX
01-13-2004 14:08:34
 Re: Re: Re: Timing Hercules IXA5 Engine in reply to Randy Kolf, 01-11-2004 12:16:03
Randy, I sent you a direct email to help with trouble shooting and will give you a direct way to contact me if you need more help.
