Restoration & Repair Tips Board
OIL PRESSURE MF TO 30
JERRY MIDDLETON
11-24-2003 16:20:46
WHEN TRACTOR IS FIRST STARTED IT HAS ABOUT 30-35 POUNDS OIL PRESSURE. AFTER IT WARMS UP PRESSURE DROPS TO O-2 POUNDS. TRACTOR DOES NOT SMOKE OR USE OIL. DO I NEED NEW OIL PUMP? ANY SUGGESTIONS APPRECIATED, THANKS, JERRY
rjo
12-07-2003 16:00:28
 Re: OIL PRESSURE MF TO 30 in reply to JERRY MIDDLETON, 11-24-2003 16:20:46
r u from happy, tx area?
Bill
11-26-2003 06:24:18
I had this happen to Farmall H. Found worn bearings both main and rod. Also found that the tube going from the float to the oil pump had corroded and was full of holes. This would allow air to enter the pump. Most likely the pump is not bad just other things.
tony
11-24-2003 20:31:45
This may be due to stuck oil relief valve open, foreign material on valve seat holding valve open, clogged suction strainer, excessive bearing wear, low oil viscosity, faulty gauge
AZ Jack
11-24-2003 18:31:59
My guess would be worn mains.
JMS/MN
11-24-2003 17:03:35
Sounds like major wear on bearings on the crank and rods. Too much space on mating surfaces when the oil is warm and runny.
