Understanding Compression Ratio
Richard
12-12-2001 05:28:37
I'm a little under educated about 1-16 compression ratio, Is it 1 part fuel to 16 air, or 16 cu in compressed to 1. Does higher compression require more piston rings with tighter clearance? How will this effect wear compared to less compression?
david
12-12-2001 14:46:14
 Re: Understanding Compression Ratio in reply to Richard, 12-12-2001 05:28:37
One way to envision compression ratio is to imagine 16 ounce bottle and squeezing the contents into a 1 ounce cup. This gives your 16:1. The is different than the fuel air ratio which is the number of parts air to each part of fuel required for combustion.
I agree with the other post that you would expect more wear (high compression gasoline engine for example)than with lower compressions. The counter balancing effect in diesels is they are designed to run hotter. This means that the individual components must be LOOSER to allow them to tighten up with heat expansion. To seal the engine and maintain compression for fuel ignition more sophisticated oils must be used as the oil provides the only seal between the piston ring and cylinder wall in any engine. These same oils must provide adequate lubrication at the hotter temps and tighter clearence when the engine is at operating temperature. The looser engine and higher compression plus loss of heat to a cold block results in diesles being harder to start in cold weather. Listen to a diesel knock on a cold morning. To maintain the higher compression, more rings, of better material are typically (but not always) used. Especially if a turbocharger is used to increase manifold air pressure.
TH
12-12-2001 07:23:45
The compression ratio means the ratio between the largest and the smallest possible volume in the cylinder. The volume is largest when the piston is in the beginning of the compression stroke (down) and smallest when it is in the end of the compression stroke (up). In other words the ratio 1-16 (or 1/16) means 16 cu in compressed to 1 as you already said.
I don't know much about the other questions but here is my 2 cents worth. An engine with higher comp. ratio (diesel engine) is subjected to more wear, but such engines are made of better materials to compensate this. So they will last at least as long as lower comp. engines (for example gas engines). I would also think it is obvious that the high compression engine needs more and better piston rings than lower comp. engines.
