Restoration & Repair Tips Board
help transmission trouble
main
11-09-2003 07:48:33
i have a 380b case the shuttle shift seems to be stuck in a foward gear all the time even when you have it in neutrel the tractor will go forward if you put it in reverse it will kill tractor any help would be appreciated thanks
Mark
11-15-2003 14:40:04
 Re: help transmission trouble in reply to main, 11-09-2003 07:48:33
Tranny is stuck in first from a worn shifter. Pull shifter out of tranny and line up the un-centered shift dog with a prybar, tranny is now in nuetral. Shifter may need some grinding and welding to build it up. Simple problem that seems like a major failure.
