Restoration & Repair Tips Board
farmall A rebuilding
tom lehman
11-06-2003 15:01:20
Help! I am restoring my fathers Farmall A, mid 1945, and the block is cracked. How/where do I find a replancement? Is this tractor possible to be converted to diesel now?
Thank you
Jim
11-08-2003 07:43:05
 Re: farmall A rebuilding in reply to tom lehman, 11-06-2003 15:01:20
I just bought a used Block out of a "B", that appears to be in good condition. I am in the process of tearing down my "A" for a rebuild.
My block was only cracked on the outside and not the inside.
Where is yours cracked, and what part of the country are you in?
CNKS
11-06-2003 20:20:39
Anything is possible, but if you want a diesel, it is best to buy another tractor. Having said that there were some diesel C's made, I believe in France or Germany. The gas engines in the C and A are identical, except for the hole in the block for the hydraulic pump, but you are probably going to look a long time for one of those in a diesel version. Replacement gas blocks are relatively easy to find. Call Mike at Steel Wheel Ranch -- 785-548-7437. You can also have the block repaired if it is not too far gone.
old
11-06-2003 20:03:51
I know of a place that has them but your looking at about $1200 but that is a drop in block, pistons etc included send me an e-mail and I can give you there phone number. I can't post it here
CNKS
11-06-2003 20:23:33
 Re: Re: farmall A rebuilding in reply to old, 11-06-2003 20:03:51
Phone numbers are ok, it is web links that Kim doesn't like, I've never had a phone number rejected. Probably given OEM Tractor Parts and Steel Wheel Ranch a hundred times.
old
11-06-2003 21:21:13
 Re: Re: Re: farmall A rebuilding in reply to CNKS, 11-06-2003 20:23:33
every time I try it doesn't work
old
11-08-2003 18:19:31
 Re: Re: Re: Re: farmall A rebuilding in reply to old, 11-06-2003 21:21:13
[email protected]
CNKS
11-08-2003 18:12:14
If it is your own business you are mentioning, Kim has found out about it, and everytime you give a phone number, your IP address is blocked. She will not block your email address though. I don't have a business, but certain web addresses are blocked -- I don't think Steel Wheel Ranch is a direct competitor to this site, OEM Tractor Parts is, but the one that really gets blocked is Vaulew built, if I spell it right, more often than not it gets rejected. If you are not a business, I have no explanation.
