Restoration & Repair Tips Board
Nuffield 342 querey
Jimmy
11-05-2003 13:13:03
Hello, I have had a Nuffield 342 that has just developed some sort of hydraulic problem. I havn't had the tractor long and know the oil in the transfer case was at the bottom of the dipstick ( very low)when I bought it, however all the hydraulics worked well and my intention was to replace the oil before the tractor did any work. I have not really used the tractor as I needed a slasher, so now I have a slasher. I hooked up the slasher (5 foot) and made sure everything functioned when the hydraulic lift just stopped working I thought the best thing would be to replace the oil to the correct level with fresh oil. I did that. The lift still does not work and my querey is, could it be I may need to bleed the hydraulic system of air ? And what do I undo to bleed the system. Could anyone offer suggestions.
The control lever that engages the lift/lower action of the hydraulics still has the same "feel" , as if it is still doing something, but nothing moves ?
Thanks for this excellent website/resource.
Jimmy - Australia
john
03-17-2004 02:10:15
 Re: Nuffield 342 querey in reply to Jimmy, 11-05-2003 13:13:03
make sure the lock isnt in on the top
TO35
11-07-2003 02:57:15
Jimmy....Try this site has alot of nuffield manuals online, you might have to remove the last word in the link and put in your tractor model..
(345) this ones for a (425)...or you can do a search on google..
good luck
best wishes
TO
Jimmy
11-10-2003 16:24:47
 Re: Re: Nuffield 342 querey in reply to TO35, 11-07-2003 02:57:15
Thanks for your help TO.
I went and purchased another drum of oil and filled to the correct level and away she went, the hydraulic lift worked first time no problems.
I attached the slasher and made easy work of 4 acres of thigh high weeds and grasses. Even the draught levelling control worked well.
Just out of intrest the transfer case took 55 litres of oil.
TO35
11-11-2003 15:43:30
 Re: Re: Re: Nuffield 342 querey in reply to Jimmy, 11-10-2003 16:24:47
Your very welcome Jimmy...glad to be of some help and thanks for posting back the results I'm sure this info. will be needed by someone in the future..
best wishes
TO
