Restoration & Repair Tips Board
Separating Rusted Rims
Paul Butler
10-28-2003 06:10:59
I have a rim and a rim spacer that have been rusted together for at least 10 years. Tractor has been shedded but the stuff is solid.
I have been beating my brains out with WD40 and a rubber mallet but haven't had any luck in budging it.
Do you guys have any tips for separating stuff like that?
(Unfortunately there are no holes or anything I can put a jack on or anything)
Willy Young
10-29-2003 17:33:46
 Re: Separating Rusted Rims in reply to Paul Butler, 10-28-2003 06:10:59
You may want to look at a posting I made a few days ago about rust removal. You can use a battery charger and water. It will cause the rust to disapear. I restore a lot of woodworking tools and machines. I have found out that if I have rusted bolts and can't get them loose that sometimes they can be loosened after a "cleaning". sometimes you can even loosen them by hand after being cleaned.
jake
10-28-2003 07:16:36
A rubber mallet is not a tool use heavy hammer with a wood driver.
R. Marg
10-28-2003 06:26:25
try poreing some turpentine on it it eats rust and work well for on locking stuck engines etc hope this helps
