Restoration & Repair Tips Board
valve guides
tcr
10-27-2003 15:11:30
I am rebuilding a case model c. I'm not sure if i should replace the guides or not. they seem to be worn at both ends, about .010 larger then in the center of the guide. at what point should they be replaced? Any info would be helpful
thank you
JOCCO
01-03-2004 19:10:22
 Re: valve guides in reply to tcr, 10-27-2003 15:11:30
I DONT Agree with jerry on the kurling a bronze sleeve or knew guide is much better: kurling is a used car lot repair
george md
11-02-2003 22:31:18
tcr,
Valve guide clearence minimum is .0025 and
worn limit is .0055 (clearance between stem
and guide).
george
george md
11-02-2003 22:18:07
tcr,
C and D engines have replacable guides ,
drive them out and drive in a new set .
george
Jerry B
10-28-2003 05:57:45
AT this stage of wear you will need to do something to the guides. Replace them or line them with bronze guide liners.
If it was me ( I have the tools) I would knurl the guides to the original size. This would re-establish the correct size and align the walls with the original center line of the guide. Run the boring bar through the guides to open them up to recieve the liners. Install the liners, spiral to a tight fit within the guide and then size each guide to fit a particular valve stem. This will last for years.
