Restoration & Repair Tips Board
Sleeve
Mike
10-25-2003 12:32:02
I need 1 engine sleeve for a B farmall. The pistion dia. is 3.100". I measure the sleeve dia. at 3.125". This tractor was rebuilt and then stored for about 25 years. Water got into 1 cylinder and pitted it pretty bad. Everything else seems O.K. Where can I get only one sleeve. Thanks for any info. Mike
Joel
10-29-2003 06:31:28
 Re: Sleeve in reply to Mike , 10-25-2003 12:32:02
Check the dimensions on your old sleeve. Sealed Power may have a sleeve that will work. The part number is SO-1779. The dimensions are: Lenth=6.875", sleeve diameter at lower sealing land=3.310", lenth from top to sealing ring land=4.688". The bore is 3.125". Check with any engine machine shops in your area for availability.
Mike
10-29-2003 14:35:39
 Re: Re: Sleeve in reply to Joel, 10-29-2003 06:31:28
Thanks for the help. Mike
cole in mo
10-26-2003 04:12:26
try going to your local NAPA parts store, I got just one sleeve for a Allis D-17.
