Restoration & Repair Tips Board
oil pressure
R. Marg
10-24-2003 21:08:08
I looked at a tractor today it had a bad oil pressure gauge on it put a new one on it when I started it the pressure was about 20 psi but after it got warm it dropped down to around half of that the oil was just changed and 10W20 was put in does the weight of the oil make any differance and should I run away from it instead of buying it?? please any answers will be welcome and thanks for your input
Jerry K. L.I. ,N.Y.
10-24-2003 23:48:51
 Re: oil pressure in reply to R. Marg, 10-24-2003 21:08:08
Ford Motor Co. recommended straight weight oil in older engines , 5 W for winter running--.So I asked why? Engineer stated the cranks and rods had factory drilled holes much larger. The new eng. have smaller holes , so they can run Multi-grade oils. For faster and better lube. as well as cooling. When we came home from the races -- tried it on my Nephews 2-N , the Engineer got me that time. Hope this Helps
Jerry.
