Restoration & Repair Tips Board
valve springs length
Jim mccarty
10-17-2003 20:13:42
I have a older briggs engine (model 130292 type 0369)on a tiller and I am trying to improve the horsepower have gone thru carb,govern,without much improvementnow the head and valves or now off and looks fair to good inside valve seats ok, some small scoring on the bottem of cyl,my question is the valve springs are a different length about 3/8 inch, exhaustlonger,is that right?also find mold ridges under both valves, 3/4 inch under seat, can I grind these off for better flow in and out?thanks
Jim
TO35
10-19-2003 04:42:08
 Re: valve springs length in reply to Jim mccarty, 10-17-2003 20:13:42
Jim....I build briggs racing engines for my Brothers go-kart team. Those engines where designed to run thier best at 3500rpms. But if your looking to increase your power the governor will have to go first. Answer to your question is yes the exhaust spring is longer than the intake.
If you want cheap power first take out the governor, then you can open the intake port up some as your looking at the port work mostly on the left side of it with a die grinder and just clean up the casting marks on the exhaust don't cut much there because by volume and flow its already to big...next take your carb. apart and either drill out the jet to .41 or you can replace it with alike holley carb. jet. And lastly roll the engine over till the piston is at top dead center, and you can start from valve towards the piston with a die grinder and remover the metal in an upward motion taking care not to cut below the top ring line you will want an up hill flow and a roll over into the cylinder...and shave the head down about the thicknes of a head gasket....
Thats where the most power will be gained...
You can also do away with the points...just remove the cover and discard points etc. and cut the wire at the back of the coil then put you a dab of silcone over the wire end. , when you install the flywheel turn it to 1 keys width to the right past where the key would go add just a touch of locktite between the flywheel and crank mating surface and tighten the starter nut as tight as you can....now your all set your timing will be advanced about 8 degrees and that baby will fly.
I realize your dealing with a tiller and just want more power but you will not see any power gain unless you get rid of the governor period.
Just taking out the governor will give you more than you will need on a tiller...if you want mucho power then the things above will put you over the top and some where around 9 to 10 hp...
or if you have a local go-kart racing shop stop in and check them out you will find tons of briggs goodies there....or check out these guys on the net.....www.arcracing.com look at thier tech tips section.
If I can help your futher shoot me an email(take out the no spam part)
goodluck and best wishes...
TO
Jim mccarty
10-19-2003 20:11:05
 Re: Re: valve springs length in reply to TO35, 10-19-2003 04:42:08
thanks for the web page and the Ideas on improvments I think my tiller may need racing tires if I use all the good hints.
Jim
R. Marg
10-17-2003 21:02:45
be careful with grinding we had a briggs that the valve seat popped out so we had to junk the block one of the best ways for more power is a biger carb like if you have a 7Hp put an 8 Hp carb on it there are other thins to do but these are the cheap fixes
