Restoration & Repair Tips Board
tricks to fix the problem
R. Marg
10-10-2003 10:45:58
if you have a problem with overheating try running some vinegar in the system for a day or so then flush it out its cheaper then what you get at the parts house and works better or at least it did in my Oliver 77 and also if you have a locked up engine put turpentine in the cylinders for a day or two and if its going to give it will with turpentine and its also good for removeing rust from parts
