Sandblasting
Sonny Heath
10-11-2001 22:50:37
Could someone explain to me how to prepare a tractor for sandblasting? Its a Lanz Bulldog one cylinder two stroke hotbulb made in Germany and repair parts are not available, so I'm worried about sand going where it dosen't belong. Thanks Sonny
Tyler(WA)
10-12-2001 10:28:25
 Re: Sandblasting in reply to Sonny Heath, 10-11-2001 22:50:37
Everything I've read and heard about sandblasting says that you need to prepare for sand to go everywhere it doesn't belong. No matter how much you mask and tape, you should tear everything down just to make sure the sand is cleared out.
It's best if you tear everything down first and sandblast the pieces before you put it all back together.
Use a blast cabinet where you can and a real good respirator when you can't.
richard
10-30-2001 13:53:55
 Re: Re: Sandblasting in reply to Tyler(WA), 10-12-2001 10:28:25
You can mask with rubber 'cos sand bounces off. Make up sheet steel/ally plates to cover any important mating faces. Get some paint on the cleaned areas real quick 'cos blasted steel rusts very fast then clean the important places with air jet and kero. What Lanz have you? I have a 22/38 and an Ursus.
