Restoration & Repair Tips Board
Radiator pin-hole leak - can it be repaired
Mike
09-19-2003 06:28:32
Just notice the smallest of leaks by the radiator cap "stand-off". It makes small bubbles, but still loses fluid and pressure. Can this be fixed?
david
09-24-2003 14:55:19
 Re: Radiator pin-hole leak - can it be repaired in reply to Mike, 09-19-2003 06:28:32
It can be soldered, A big bottle of Bars-Leaks would be easier. All modern car manufacturers use bars leaks on ALL cars off the assembly line. They get it in tablet form but the stuff you can get is the same.
nf owen
11-25-2003 19:26:13
 Re: Re: Radiator pin-hole leak - can it be repaire in reply to david, 09-24-2003 14:55:19
go to any gm dealer. the tablets are 6 to a pack, $2.50, used to seal all gm etc engs w/alum parts. it works
