Restoration & Repair Tips Board
need suggestion with a rearend on a bolens 1220
steve
09-15-2003 15:33:50
I just bought it and the rearend locks up. I was told there is some kind of a lock but I am not sure. Can anyone give me some imput on what it might be or how to fix it.
Bob WHitmoyer
09-16-2003 17:43:01
 Re: need suggestion with a rearend on a bolens 122 in reply to steve, 09-15-2003 15:33:50
Hi Steve
Not real sure what you mean by "locks up". The Bolens has a posi-traction nut on the left rear wheel(sitting on the tractor) and a wheel lock pin(free-wheeling pin) on the inside of the right rear wheelhub. You pull this out to be able to push the tractor otherwise it won't move.
The posi-nut is screwed out for one wheel traction only and in for more degreed of two-wheel traction - clear in tight is "locked rear end. If the tractor locks up while moving under power, make sure the high-low range lever is working ok- full travel. Ping me back with more info if this dosen't help
Bob Whitmoyer
