Restoration & Repair Tips Board
Tank Leaks?
Paul
09-07-2003 13:01:10
I've developed a gas leak near the fill tube on my Model B JD tractor. I have the tank off the tractor now. What's a good internal gas tank sealer and is it difficult to use?
ThankS!
Mike
09-09-2003 09:29:28
 Re: Tank Leaks? in reply to Paul, 09-07-2003 13:01:10
Why don't you just solder it !
Paul
09-10-2003 02:57:33
 Re: Re: Tank Leaks? in reply to Mike , 09-09-2003 09:29:28
Mike; My leak turned into many leaks when I looked a little closer. I don't think I can buy enough solder. Thanks for the suggestion. Paul
Gene
09-20-2003 09:24:25
 Re: Re: Re: Tank Leaks? in reply to Paul, 09-10-2003 02:57:33
motorcycle shops or dealers have a tank sealer they sell it works really well the brand sealer i bought is called Kreem but all the rust must be removed from the inside and or outside of tank it will seal and act as a liner; my gas tank was really bad rusted on the inside had to use muratic acid on it before i could use the liner. Good Luck on your tank ;Gene
