Restoration & Repair Tips Board
Welding a cast sprocket
Rob Mo.
07-27-2003 18:46:07
If you can weld one thing, then weld anything that breaks. I'm talking cast sprocket on the machines of yesterday. I got a piece of a sprocket off of a combine feeder driver. Is that particular piece weldable & I don't have to worry about it the next time I use it?
Farmer John
07-29-2003 10:26:28
 Re: Welding a cast sprocket in reply to Rob Mo., 07-27-2003 18:46:07
I use Super Missile Weld from my Hobart supplier. I have welded all types of cast iron and cast steel with this rod with excellent results. Always preheat.
george md
07-28-2003 00:23:36
Rob,
you will probably here a lot about how good nickel rod is for welding cast , but the best thing to do with ni-rod is to leave it in the box.
Cast iron comes in a stick some round and most square rods and is used with torch and proper flux. preheat the sprocket to several hundred degrees with large soft flame torch , then weld with medium neutral to slightly rich flame .Cool slowly I have and do use ni rod - but there are very few jobs that will weld as good with nickel as with torch, and even fewer that will weld better with nickel. I have most likely stirred a hornets nest here , but most of those that tell you how great ni rod is , have never tried acetylene / cast iron .
questions - email me
george
Rob Mo.
07-28-2003 08:53:37
 Re: Re: Welding a cast sprocket in reply to george md, 07-28-2003 00:23:36
Thanks for your reply. There is one thing that has got me mind boggled. How good do these welds hold up under pressure? What is their cracking point?
george md
07-28-2003 21:50:06
 Re: Re: Re: Welding a cast sprocket in reply to Rob Mo., 07-28-2003 08:53:37
Rob, The cast iron in the rod is as near a match to the material in the sprocket as you will find without going back to the foundry and getting some of the original pour . If you grind it so that you can get 100 % weld and do a good weld , it should be as strong as the base material . I do quite a bit of cast iron welding with torch andsome of it requires machining after welding,
and that is when you find out how well you did welding the piece .
george
